Mugs not printing correctly (pics included)
Re: Mugs not printing correctly (pics included)
I just noticed on the picture with your mug press sort of rubber sheet. is this fited to the blanket or just extra bit you use ?
you also said you got some kind of Birmingham mugs. I never heard of them. is it possible you trying to print on wrong mugs??
i changed all sorts of stuff - and still they not coming out perfect
@ Paul - the mugs where sold to me with this setup as Sublim mugs - on brown box it just says Birmingham ZZ made in china
Box is full of little white boxes holding the cups
The rubber sheet is fitted to the actual press as the thin rubber bit is what warms up (heat pad) the foam pads behind it are the cushioning
the stone stays in
we have the same press,we press for 3 mins at 180
stu
stu
RICOH GX 7000 ROLAND GX24 ROLAND VP300
The first press I bought did that and also showed the element marks on the paper as a burn I had to replace the blanket.
It may well be the mug press fault. is good to make sure and then contact the ebay seller if sold as a working machine.
yeh im think its the burner as well as the prints are coming out ok from the printer
on the blanket is little imperfections - i think its these that are causing the marks on the cup
As for the seller - not a lot can do as brought it off private seller so i have no comeback (infact brought last sunday so less than week old)
Infact i just checked his returns policy and he does accept returns.
But here goes - ive already used the stuff off him to make cups which none have come out.
Can i still return ???
if you paid via paypal you are covered
but if you bought direct of ebay they won't help obvioulsy
and you are allowed a reasonable amount of time to test equipment
yeah. same assteve! if payed with paypal then you covered no matter what
is sold as working and is not now
end off.
end off.
no paypal LOL
i had to travel and pick it up
was cash on pickup im afraid
But he does have a return policy but i have obviously been using it to print stuff thats how know its the mat now as the same imperfections are on the mat as well
I brought the complete setup off this guy on ebay
Sale date: 01/01/12
and i picked it up few days after the post ended - so i not even had it a week as yet.
Just noticed this on his sell post on ebay :
Return policy[TABLE="class: vi-rpd-tbllyt]
[TR]
[TD="class: vi-rpd-rpdContent]Returns are accepted – please see the details below;Items must be returned to in an unused condition as new condition with all tags ect where possible. You must contact us within 7 days of receiving an item in order to returning it. Personalised items cannot be returned unless there has been a problem caused by us. Refunds are only given when goods are received by us. All return postage costs to return the items are the responsibility of the buyer. We will replace any damaged or faulty items. Please contact us before leaving negative feedback as we always try to resolve any problems.
[/TD]
[/TR]
[/TABLE]
Sale date: 01/01/12
[TR]
[/TD]
[/TR]
[/TABLE]
- mrs maggot
when you picked it all up did he take you through the process, and did you print up a mug or two while you were there ?? if not, he may well have known that things were not right with the machine
