Maybe someone could tell Sawgrass that so they can get it right and stop clogging Epsons!bms;36368 wrote:Problem is that a little change in consitency can have a significant impact of printability
Refilling Ricoh 3300 cartridges
Re: Refilling Ricoh 3300 cartridges
I was waiting for that one !Justin;36371 wrote:Maybe someone could tell Sawgrass that so they can get it right and stop clogging Epsons!
Might be something to do with me not having any blockages anymore since using ****** inks. Me & my S21 are still very happy bunnies. :biggrin:Justin;36371 wrote:Maybe someone could tell Sawgrass that so they can get it right and stop clogging Epsons!
The ink is definitely different. Inks in Epson/ Canon printers is very watery (I'm talking about the genuine inks, not sublimation inks). The ink inside the Ricoh cartridges is thicker. I'd compare the difference a bit like comparing wine 'legs' in a glass when you swill it around (Epson & Canon inks) and single cream in the same wine glass. Still liquid (not gel like hair gel), but certainly thicker.bms;36368 wrote:Problem is that a little change in consitency can have a significant impact of printability - take the consistencies of genuine inks and some compatible inks. A very slight change can result in no print at all! Best test is to open a Ricoh cartridge and look at the ink yourself - I've plenty of these kicking around the warehouse...
Martin, now we are printing with wine and hair gel!!
It dozen get any betta than this
If only i knew what i was doing....
Shutz
Shutz
It would probably be cheaper if we did!Shutz;36467 wrote:Martin, now we are printing with wine and hair gel!!
Users browsing this forum: Amazon [Bot] and 10 guests
