Page 2 of 2
Re: Problem printing polymer coaster
Posted: 14 Oct 2011, 22:49
by Paul
I never said that you "should" but there is few post on here about ricoh that need bit lower temps as prints may look funny.
Posted: 14 Oct 2011, 23:02
by John G
Paul's right, in certain circumstances the blacks over cook and turn brown - its a gel ink which is different to the ink used in epson. Its worth a try dropping the temp!
Why are you using a profile, can you not use the powerdriver?
Posted: 15 Oct 2011, 08:01
by Listawood
Are you printing the coasters print side up in relation to the platten or print side down?
Alex.
Posted: 15 Oct 2011, 17:06
by tiptreegirl
I'm printing with the print side up. Will they work print side down?
Posted: 15 Oct 2011, 17:07
by tiptreegirl
John -sorry, I am actually using the powerdriver
Posted: 15 Oct 2011, 17:14
by John G
I've only ever done the wood ones so cannot really help - if the print on paper looks solid, and not washed out, then it's either the sub item or you heat press or platen.
Posted: 15 Oct 2011, 18:00
by Listawood
not if it's wood. You can print ceramic or aluminium by heating through the back of the substrate - I was wondering if you were trying to do this with a blank that doesn't conduct heat well and hence the problem.
Alex.
Posted: 15 Oct 2011, 19:46
by tiptreegirl
Thank you to everyone who has had input with this. I have finally got it printing and looking good, but I did have to get rid of the black background. For starters, the black background wraps down the side of the coaster a little and looks bad. For anyone else trying to print on the polymer coasters, I was told to use 190-200C for 50-60 secs and I ended up using 175C for 3.5 mins. I am now using a white background with black and red text/images and they look great with the lower temp and long pressing.
I appreciate everyone's help! Now for a drink....it's saturday night after all;)
Posted: 15 Oct 2011, 20:06
by jennywren
Is it me or is 3.5 mins long for a coaster.
Posted: 15 Oct 2011, 20:58
by John G
Longer than a mug - that cannot be right!
