My first mug
Re: My first mug
I never adjust any photo apart from when it needs cleaning up, cropping, adjusting the lightness etc - straight out of the camera is best. There's no need to adjust anything - that is, if your printing from Coreldraw - never printed from photoshop.
Re: My first mug
what i meant was should i be using high dpi print settings
also got instructions for my press they say bring upto temp 180 then place mug in and immediately count down from 200 secs
Re: My first mug
Yes but what program are you printing from - can you not print, as the photo comes, or do you have to set values when opening the photo.what i meant was should i be using high dpi print settings
Use the instructions given with the press - if they don't work bring the seconds down to 180
