looking for new mug press
sarahjayne
Re: looking for new mug press
Post by sarahjayne »
There number is 0845 2249917 - it's on top of the home page. Just brought the mug press home and hope to get my first one done tonight. They were great to deal with and super quick UK delivery.
purpledragon
Post by purpledragon »
jennywren;30980 wrote:Is there difference, because of the price. I didn't understand about the idling, time, can you not take one mug out and put another in straight away, sorry if I sound stupid but when I have a large order I need to keeping going
I have one of the bms machines they're cracking little presses for the price, i use mine for money boxs and thermal mugs. RE idle time :this is a neat little feature what it means is your press will heat to a predecided temp when you press the timer button it heats up to the correct temp then counts down as normal. if doing a run of mugs you wont really notice anything as you take a mug out you put one in and press the button for the timer . but if you had a break between mugs the temp cools back down to the predecided idle temp until required again. this helps in 2 ways firstly you dont use as much electric by heating the press up fully until needed and it also help prolong the life of the blanket.
jennywren
Post by jennywren »
well hope all goes well with your first mug. Which mug press did you go for
jennywren
Post by jennywren »
Just went on to order the mug but it's not coming up, hope it just a blip. Just phoned no one home just the machines...
jennywren
Post by jennywren »
I have gone ahead and orde the mug press will let you know what it's like
So what one you decided buy Jenny?
jennywren
Post by jennywren »
I brought the one from coralgraph, it was with the discount for members of this forum it was 114.00. I could not justify spending to much on a back up with will hopeful just sit there till I have a crisis, if that makes sense
jennywren
Post by jennywren »
I brought the mug press from coralgraph it was 114 pounds to but vat and postage, I tried the mug press out today when it arrived, struggle with how to set the time and temp, but a quick call and a return email from them with fresh picture instruction and away I went, I had a small order of 35 mugs which I did, and they turned out well. The mug press is good and easy to use.
