Re: Glue Spray thingy - what's it called?
Posted: 11 Jun 2011, 21:22
Brilliant find John. I looked high and low last time Subli Supplies ran out of stock.
I've used this since starting up nearly 3 years ago. It seems expensive but a can does last a long time. If you get the wrong tape it can leave marks. You can also get movement when putting the press down with tape, the spray is a lot better for holding in place.
I suspect the can size is the same but my cans are at the shop.
