Brilliant find John. I looked high and low last time Subli Supplies ran out of stock.
I've used this since starting up nearly 3 years ago. It seems expensive but a can does last a long time. If you get the wrong tape it can leave marks. You can also get movement when putting the press down with tape, the spray is a lot better for holding in place.
I suspect the can size is the same but my cans are at the shop.
Glue Spray thingy - what's it called?
Re: Glue Spray thingy - what's it called?
What's it like then mate when you have to remove the paper after pressing? Does it come off easy enough due to using the spray?accdave;24555 wrote:Brilliant find John. I looked high and low last time Subli Supplies ran out of stock.
On t-shirts it's an absolute doddle.AdamB;24556 wrote:What's it like then mate when you have to remove the paper after pressing? Does it come off easy enough due to using the spray?
I rarely do mousemats but when I did try it once from memory it did stick and I went back to using tape. I'll try that again on Monday and see what happens.
