Page 2 of 3
Re: mug colour test - a must have
Posted: 26 Apr 2011, 16:16
by JSR
It's worth bearing in mind the relatively tiny colour gamut from dye-sub inks. For example, if you compare the Sawgrass-supplied Epson 1400 profile with the Epson-supplied profile, the Sawgrass one is tiny. This demonstrates how weak Artanium inks are in comparison to OEM inks that are designed for photos.
I compared the Sawgrass-supplied profile for the Epson 1400 with the Epson profile for my 4-colour laser printer - and still the Sawgrass profile is tiny in comparison, which suggests that I can get more accurate colours out of a CMYK laser printer than from Sawgrass CcMmYK inks.
That's no surprise, of course, because we're using the same Artanium inks in today's printer that we were using in printers 10 years ago. The ink hasn't changed, developed, evolved, or improved. We often bemoan the likes of Epson because of their high ink prices, but at least OEM printer manufacturers constantly develop/improve their inks. All certain dye-sub ink manufacturers do is to take our money for their expensive ink and occasionally let us have a profile (usually just before a printer is about to be discontinued).
Andrew;21260 wrote:We often get asked to Pantone match and haven't had a sinle complaint with the results as of yet.
If the colour you're asked for is within the colour gamut of the inkset then you have a chance of getting away with it.
Andrew;21260 wrote:Have there been previous discussions on this profiling device of Paul's? I've heard it mentioned a few times. How much is it? I'll do a search when I get a chance for threads where it might have been discussed previously.
I borrowed it before Christmas, during which time I worked on a Brother printer set-up.
The main issue I had before using the device was with an Epson B40W. When using the Sawgrass profile, photos printed with a hideous green cast over it all. No amount of tweaking would solve anything. I was on the verge of throwing a £100 printer in the bin because I believed it was just a shoddy entry-level printer. However, after 30 minutes with Paul's profiling device, I had a new profile and the results were so close to spot-on that it was just incredible. I couldn't believe the difference between the, frankly, cr*p I got from the Sawgrass profile and the near-perfection I got with the custom-made profile.
I then went to profile my other printers. I have two Epson 1400s here, one from 2007 and one from 2010. With a good amount of tweaking, I could get "good enough" prints - but with different profiles. The Sawgrass-supplied "v1" profile worked on the 2007 printer, but not on the 2010 printer. The "v2.5" profile worked on the 2010 printer but was awful on the 2007 printer. After profiling them myself, they both now produce results matching each other.
I concluded that I'd been fooling myself in my belief that the supplied profile was the solution, when it turned out to be the problem.
If you're lucky to have a printer that was manufactured within the same tolerances as the one Sawgrass used to create their profile then you'll get away with it. But if you're at the other end of the tolerance or outside it (which is very probable with entry-level printers), then the supplied-profile causes more problems than it solves.
Posted: 26 Apr 2011, 16:30
by Andrew
So how does the profiling overcome the problem "what you see on the paper isn't always going to be what you get on the mug" scenario? Do you calibrate from the actual mug print or does the profiler go as far to negate this issue by having the print on the paper coming out exactly the same on the mug?
Posted: 26 Apr 2011, 16:41
by JSR
You do the profile on the end-result. In my case, I subbed some 12x8 metal sheets that I got from BMS and then used that to create the profile.
You'll never get the print that comes out of the printer to look the same as the mug because the inks don't reach their full colour until heated.
Posted: 26 Apr 2011, 17:00
by John G
The screen printed mugs you mentioned - that's down to the screen printer and his ink mixing knowledge. If he couldn't mix it - he shouldn't have printed it. Been matching to pantone requests all my working life with screen inks - Greens can be a nightmare.
As for the pantone matching with sublimation - I don't offer it, I say i'll get as close as possible but I ain't wasting mug after mug trying to reach the unreachable. It might be different if all my orders where for hundreds or 1000's but for an order of 20 mugs with a logo on they get what they supply or what i've proofed with them.
Posted: 26 Apr 2011, 17:19
by Paul
also is worth to mention thiat you can create your screen then printer (inks) and now you get on mug what you see on the screen ;)
so thats why I cant see any point to print dots on mug.
Posted: 26 Apr 2011, 20:02
by Andrew
John - that screenprint on a mug was with the largest company from the UK in the industry. I know many t-shirt printers will lay down a base layer when needed i.e. printing light on dark, but this doesn't seem to be the case for mugs. I don't think they even adjusted the colour to try and compensate. Our orders are mostly hundred plus so pantone matching we do when asked.
Paul - do you mean calibrate the screen? Are you saying then have the screen match the printed product colour?
What we do works for us and on a large scale but if you guys have a better way then always happy to learn. Profiles have never been my thing as I leave that to someone else.
Posted: 26 Apr 2011, 20:23
by Paul
yes. I mean screen calibration. Imagin that somone sending your photograph and it looks ok on screen but not on the mug???? its not necesserly mean your printer profile is bad or faulty coating on mug etc... your screen may simply display reacher or poorer colors with diferent saturation/brightness then is realy is on photograph so screen calibration is a must in my opinion. btw... you can do printer and monitor with one tool whitch is great :)
Posted: 26 Apr 2011, 22:01
by mrs maggot
i have found it quite useful, until i have the printer set up properly, just to see what the colours look like on the mug rather than on my large screen, i dont stick photos on mugs mine is all colour work, and i am fairly new at it - adam suggested it as a good idea to see what the colours are like in a simple way, i know it does not cover every colour, but its given me a better understanding of the colours
Posted: 26 Apr 2011, 23:59
by JSR
If you have faith in the profile you currently use for your printer, it's fairly cheap to get a monitor-only profiling gadget. They're usually around £80-£100, I think. I have one here which I would willingly sell to put funds towards Paul's profiling device, but mine's a bit old now so no one would want it.
mrs maggot;21287 wrote:i have found it quite useful, until i have the printer set up properly, just to see what the colours look like on the mug rather than on my large screen, i dont stick photos on mugs mine is all colour work, and i am fairly new at it - adam suggested it as a good idea to see what the colours are like in a simple way, i know it does not cover every colour, but its given me a better understanding of the colours
I do recall doing something similar while troubleshooting a couple of years back. I couldn't get a brown horse to be brown, so I printed blocks of colours to try and see which one was the most "off" - in the hope of tweaking that colour back in on the PC. All the blocks printed close enough to what they should have been - but I still had a horse the wrong shade of brown. I guess all the blocks I printed were in-gamut, while the brown wasn't.
I wish I'd known then what I know now.
Posted: 27 Apr 2011, 06:44
by mrs maggot
well i still think for a newbie who is printing for the first time, it would help with the "paper looks faded, colours are not right" questions, and also help with the diagnosis of poorly printed mugs, if everyone did something similar like a DSF test mug would help a lot when they posted pics up lol
