Check this package out
Re: Check this package out
yes. it useto be called like that.
The DG5 is DomGlobal 5 mug press. You see where DG5 comes from.
The handle print comes from using the cap press (bevelled heat element) and the printing in the base of the mugs comes from using a plate press attachment. I think DomGlobal have a small plate element for getting into the base of the mug (if your mugs are properly coated on the bottom).
Have you seen them print the base and handle? I think there are videos floating around somewhere. We mentioned these a long while back, one issue was whether or not all subli mugs were coated on the bottom. The press looks like a very cheap Chinese one, simple chained together. I can't really see the benefit to most users above and beyond a very good dual mug press which would be far cheaper. BTW, I can see inks with the package as well. It's still a hell of a lot of money :-(
yep :( to dear. I can understand that there is a cost of press, transport from china and seller profit but this is simply a rip off. hope no one on here will make this mistake :)
accdave
Post by accdave »
Mugsman;20468 wrote:IS that a DOMGLOBAL ???
Here's your answer
www.domglobal.com
Reg
Post by Reg »
If its the 5 mug press your interested in check this link http://cgi.ebay.co.uk/Coral-Commercial- ... 4890wt_991
Kaz
Post by Kaz »
Dave
That link starts out as domglobal, then reverts to the link from the OP
accdave
Post by accdave »
Kaz;20483 wrote:Dave
Thats the point I was making Kaz. Domglobal with a name change. Anybody know why ?
Kaz
Post by Kaz »
Sorry Dave, bit slow on the uptake today, lol
Reg;20482 wrote:If its the 5 mug press your interested in check this link http://cgi.ebay.co.uk/Coral-Commercial- ... 4890wt_991
there you go :)
fraction of the price and do same job in same time :D also seller is a member of this forum too :)
