Replacing thermostat on Aadkins press? ASAP!
justme
Re: Replacing thermostat on Aadkins press? ASAP!
Post by justme »
Are you able to point me in the direction of any?
Thanks for your help...
http://www.NameArt.co.uk - owner and designer :) ...oh and mug presser!
justme
Post by justme »
Thank you - will take a look :)
you welcome. his web site is belong to Henry (coralgraph) and he also is registered member on this forum. Also is good in resolving problems if anything goes wrong. worth to have a lookm if you dont have to much to spend.
logobear
Post by logobear »
I have been using Adkins Presses for just over 20 years, only had one totally fail on me, and that over 15 years old ......
I do remember changing a thermostat, which was a bit of a chore, the main issue being calibrating the temperature control. This is no big deal for most transfere types, but is critical for WOW.
On the subject of presses, I have used others, and IMHO nothing compares with the quality, reliability, and consistancy of Adkins. We do many thousands of pressings per year, I have 3 Adkins, and seriously doubt that any cheap press is upto the work you can achieve with a good press. I should mention that much of our work is laser transfere which needs a lot more pressure than sub or vinyl.
justme
Post by justme »
Thanks logobear - I am quite determined to figure out a way of affording an Adkins one...
...if you're ever upgrading one of yours...let me know ;-)
