stamp the bottom of mugs etc
Re: stamp the bottom of mugs etc
register then lol :)
Has thanked: 13 times
Been thanked: 12 times
Links to that forum and telling our members to register Paul?!?!? Whatever next, consider yourself demoted :-)
LOL :) I dont think it anything help that forum lol :)
Ian M
Post by Ian M »
Justin;17472 wrote:Paul?!?!? Whatever next, consider yourself demoted :-)
Justin, you can't demote a legend.
smitch6
Post by smitch6 »
lol what have i started :P
Ian M
Post by Ian M »
smitch6;17531 wrote:lol what have i started :P
A lively debate Steve..........lol
R.Prints
Post by R.Prints »
I tried applying using subli but problem is getting the paper attached tight enough for it to tranfer completely. In the end I gave up and now use the water transfer paper which gets printed, cut, applied then baked in oven to cure. Good results.
Quizzer
Post by Quizzer »
Hi,
First post so be gentle with me.
Spotted these polyester stickers with marine grade glue http://www.labelplanet.co.uk/proddetail.php?prod=LP70/25RGWP would these be any good for the bottom of your mugs?
Looks like they would be sticky enough, but depends what happens when you put them in a steam environment with lots of hot water, i.e. a dishwasher.
Andrew
Post by Andrew »
Possibly a good option. Shouldn't be a problem in the dishwasher as the base of the mug faces away from the pressure but not sure how long a laser print would last.
Welcome by the way. I'm assuming you are not a newbie as your site looks fairly established?
