Travel mugs from BMS
Re: Travel mugs from BMS
barryslip;16986 wrote:Thanks Martin - super fast delivery again, the travel mugs arrived this morning...!
Just one more question before I print on them - do I need to submerse them in cold water (like the cermaiic mugs) as soon as they are removed from the heat press?
Thanks everyone for your very helpful comments on this subject.
Yes I would do. Make sure you remove the plastic top before pressing though.
Scotty@BMS
Post by Scotty@BMS »
You can do Barry. However, you may find that the transfer paper sticks a little bit, in which case you be washing them with soapy water regardless!
barryslip
Post by barryslip »
The travel mugs printed up a treat with the red logo for mu customer!
However, when pressing for 180secs (as per BMS website) the paper was very scorched but the image was OK. I pressed the next ones for 70-80 seconds and were much better.
Martin - would you agree that the website recommendation should be changed? I also found a video on (very useful site) www.Conde.com. They pressed the same travel mug for 60secs
Barry
Will look into this...
