Page 2 of 2
Re: 10 Years and only now using jigs
Posted: 03 Jan 2025, 19:41
by Mrteajunkie
I found the mdp jigs to be awful.
i threw away more coasters than I sold.
The mdf warped like nothing I have ever seen before.
I did post about these years ago when I tried them and considered the metal jigs instead but I always ended up taping them.
Posted: 03 Jan 2025, 22:32
by gazfocus
Mrteajunkie;154504 wrote:I found the mdp jigs to be awful.
Were they as chunky back then as they are now? Bought 6 just before Christmas to try and not got round to trying them yet but they’re about 18mm thick so the timer on the stahls fusion heat press won’t kick in as it’s too thick.
Posted: 06 Jan 2025, 17:42
by Mrteajunkie
gazfocus;154505 wrote:Were they as chunky back then as they are now? Bought 6 just before Christmas to try and not got round to trying them yet but they’re about 18mm thick so the timer on the stahls fusion heat press won’t kick in as it’s too thick.
Yep thick and ugly. (like gemma collins)
Posted: 16 Jan 2025, 16:18
by froggy
MDF is a poor material for any type of printing jig. It will absorb moisture so it is virtually impossible to keep the jig flat. I have manufactured mdf printing jigs for uv printing and the varying ambient moisture content warps and twists the jig. The best material for sublimation printing jigs is aluminium when cost and performance are considered. Stainless steel would be good but expensive.
Posted: 05 Feb 2025, 11:16
by GoonerGary
UK Printed Mugs;154493 wrote:The 6 coaster jigs we bought from sublimania which work brilliantly and just about to use the MDP custom ones this week (arrived too late for our large job sadly). I'll let you know about these once used.
Do they supply a template for the jig? How are you lining up the print when the printer misaligns them? I do have an idea to fix this, but it involves printing onto A3 paper instead and trimming down to shape.
So has anyone tried the new coasters yet, now that they have arrived in? How is the backing with heat tape?
Posted: 05 Feb 2025, 11:20
by UK Printed Mugs
Yes, just email them for the PDF layout. We then turned this into a Photoshop template. We print onto 24" paper and cut the templates out and place over coasters using two pieces of tape either side of paper on jig.
Posted: 08 Feb 2025, 19:44
by Mrteajunkie
The templates are on the page of the coasters and jigs.
https://www.mdpsupplies.co.uk/dye-subli ... n_coasters
scroll to the bottom and you will see the banner that says need a coaster jig template.
hit the download and your golden.
Posted: 10 Feb 2025, 21:35
by GoonerGary
That's the MDP jig though.
Posted: 10 Feb 2025, 22:44
by Mrteajunkie
GoonerGary;154584 wrote:That's the MDP jig though.
AH my bad I thought that’s what you were after!
