It looks like your print is missing black ... could be clogged, or your profile is just wrong.
I'd advise swapping to good known inks (sublinova) with a profile custom made for your printer, paper, and inks for chromaluxe sheets.
Colours
Re: Colours
I'd say your temp was too high, and would try dropping it to 180C for 60 secs as a starting point (get an infrared thermometer to check your press heat is what it says it is.
As said before, don't print a full sheet of chromaluxe for testing ... use small sections, or go and buy some cheap polyester fabric until you can see your colours are right.
