These are some good suggestions however what longer term methods would u recommend in place of inkjet transfer vinyl. The last point about only washing in one temperature seems the hardest to control if day I was to give someone a shirt. Whereas the others seem doable from my end.pw66;150095 wrote:So you were using inkjet printable transfer vinyl?
Inkjet transfers never last as long as some other methods. There is usually some fade after the first wash. They are ok for short term use.
There are several probable reasons.
- most inkjet vinyls work best with pigment based ink, not dye based ink. Dye ink is more susceptible to washing out (don't confuse 'dye' ink with 'dye sublimation' ink)
- it is best to let the transfer dry fully (preferably overnight) before pressing
- most inkjet vinyls recommend that you don't wash for 24 hours after pressing
- inkjet transfers are very susceptible to washing temperature. Cool, fast and inside out is best.
Colour changing after wash of shirt
Re: Colour changing after wash of shirt
Assuming that you want to print onto cotton then sublimation is not a viable option (although there are some sublimatable vinyls around they are not particularly good).
For printable vinyl solvent print is the obvious choice. Shouldn't fade and will last as long as the garment. Printer costs are high, with the cheapest starting at around £5k (Rolnad BN20), but you can also print signs banners and stickers.
There are also laser transfers that work better than inkjet transfers. They dont last as long as solvent transfer. There are some cheaper desktop laser printers that will work, but if you want a really good A3 printer with white toner you are looking at around £6k. Transfer paper can be expensive.
If you are thinking of either of the above methods then in terms of outlay you are getting close the the price of DTG or DTF.
A good DTG printer (direct to Garmet) will cost around £10k+.
A good DTF printer (direct to film) will cost about the same (£10k+), although I can see that coming down over the next few years.
In terms of controling how your customer washes the garment all you can do is place washing instruction clearly on the garment neck label or on a swing ticket.
You could always outsource your transfer production to someone with a dtf printer. It will increase your costs per garment slightly, but you will have no capital outlay.
Outsourcing might be the cheapest solution currently. Would have to find an appropriate supplier to fit my needs. Thanks for the suggestions and your time
