Hi Jenny,
By two levels I simply meant stacking one layer of mugs on top of each other in the oven. What I do is evenly space 5 mugs on the rotating plater, put a circular wire 'baking thing' on top and then put the remaining 4 mugs on top of this. Make sure all mugs are evenly spaced to allow for the air to circulate. Note: any more than 9 mugs will be too heavy and cause the revolving platter to stop which is no good, you want it moving. Reference clamps I use 'cactus wraps' (supplied by Martin @ BMS). I cook 9 mugs at a time for approx 25-27 mins @ 220 degrees, bingo works a treat! I have never used a mug press and have been subbing mugs this way for nearly 9 years without problem.
Hope you find this useful.
Regards
kevin.
Mug Ovens
Re: Mug Ovens
Sorry should also have mentioned you are 'oven cooking' and not 'microwave cooking' just to clear up any confusion.
Kevin.
Kevin.
benwilliamson
Re: Mug Ovens
Which conveyor oven are you looking at, Hix?Andrew;16657 wrote:I'm looking at the bigger industrial ovens really and after a meeting yesterday probably heading toward the conveyor type again.
Users browsing this forum: Semrush [Bot] and 3 guests
