Page 2 of 2
Re: Mugs - faded bottom edge.
Posted: 14 Apr 2021, 13:01
by JMugs
Why not just create your own mug template, it's just a rectangle?.....:confused:
Janners
Posted: 14 Apr 2021, 13:06
by Iby
I know its just rectangle but again Im having to mess about with it on the guillotine to get the right cut out so to make life easier I was just being lazy and wanted a pre-template so Im always on point - with or without a bleed.
Posted: 14 Apr 2021, 14:10
by knightweb
While you are getting started with Dye Subbing mugs, have you considered mug designs that have a 10mm or so gap top and bottom. If you have 3 up designs on a A4 sheet, you will have a good gap to the handle, less headaches while you hone your skills.
I don't know where you are looking to sell, in my view, the 3 main online selling platforms carry a lot of mug designs as above. Premium priced mug designs, 2 up on a A4 sheet, tend to be Top to Bottom and Close to the handle, were experience and probably an oven helps no end, just my personal opinion
Posted: 30 Apr 2021, 06:44
by ZoeCF20
The straightest edge mugs we have used are Xpres, recently got some from Novachrome during the mug drought and they were fine to get us through until shipment arrived. All others we have tried over the years have given us problems but they could be different now.
Sometimes flipping a mug half way through can give you better results on bottom edge ie putting the bottom of the mug at the other end of your press. Hope that makes sense!
Posted: 30 Apr 2021, 09:43
by Iby
knightweb;147966 wrote:While you are getting started with Dye Subbing mugs, have you considered mug designs that have a 10mm or so gap top and bottom. If you have 3 up designs on a A4 sheet, you will have a good gap to the handle, less headaches while you hone your skills.
Just purchased Subliflex Pre Cut paper which has helped a lot for me. Some background. Slipped Disc 5 yrs ago and messed up Root Nerves in Spine so cant do much i.e. work. Only till recently I discovered I can make use of Illustrator and bought a mug press (long story short) in terms of selling.. its more so Hobby /Craft with intent to sell but there is no way Im looking to open shop. Cant do it on my own.
I cant get a hold of express mugs to give them a try but Ive been getting much better results fiddling around with Printer Settings as such. To get around the fading bottom and edges Ive only been placing an image 100 or 200mm away from both handle, top and bottom & its been fine. But TY 👍🏼
Posted: 30 Apr 2021, 09:46
by Iby
A noob in the game so I wasnt aware of this drought. Seems like the BSM euro and Xpress were sold out everywhere. Glad you guys got some more in.
when you say halfway through, Im assuming you mean halfway whilst its being pressed, so half the timer, turn the mug around and then back onto the heat? Wont I run the risk of the image slipping or moving?
i have flipped the element also to see if that helped but nah. In all honesty It may just be user error, I may not be applying the image on correctly or using my tools properly. But TY ����
Posted: 03 May 2021, 09:47
by MattMose
One simple solution as recommended to me from another user on here (WebTrekker), use a halogen oven. £30 from amazon.
Even with the Listawood Genie 3 Mug press I was still getting issues around the edge of the element. Swapped to using a cheap halogen oven (didn't believe it would work but for £30 it wasn't too much to lose).
Consistent heat all around, the green silicone mug wraps are about £5-£10. My mug press is now gathering dust. I use it if I have a design that goes nowhere near the edge, but most of my mugs are full 230mm top to bottom.
