Re: Halogen Ovens?
Posted: 22 Feb 2020, 13:36
Today i found out another good reason for an oven, i experimented alot with my mug press today and this press has a very dense heating element, probably better than super cheap mug presses. I could eliminate my fading issues BUT if you look really close under a bright light you can see the pattern of the heating elements on the mug, especially in dark areas, in an oven this can never happen because the heat is evenly distributet. Thats why i think the oven gives better results, i think i made a 180 Euro mistake, thank god i could buy the 88 Euro Amazon halogen oven for 20 and a cheap silicon wrap for 10. I will test that out when it arrives next week. You dont have that fishy chemical smell as well which coats your throat and teeth.garyuk;142085 wrote:Why do you use a halogen oven rather than a dedicated mug press? are there any actual benefits to using the oven?
