True pix paper sticking to surface
Re: True pix paper sticking to surface
Thank you, it does make sense. I also read somewhere that light pressure gives better results on metal sheets, maybe it's coating dependant. I'll try 50sec@185deg and report the outcome.
Hope you have success with it.milo;13918 wrote:Thank you, it does make sense. I also read somewhere that light pressure gives better results on metal sheets, maybe it's coating dependant. I'll try 50sec@185deg and report the outcome.
