Page 2 of 2
Re: Where am I going wrong?
Posted: 16 Aug 2019, 14:36
by Rusty
InkExperts;139557 wrote:Ok, looking at your printer settings the drivers are not installed fully.. you have the bare bones Windows driver rather than the full Epson driver. Without the full driver you cannot follow the colour management setup guide. i.e there is no advanced area to turn off the printers icm to leave the icc in control of the colour.
I would say that is the main issue here. Teal / aqua colours are notoriously tricky to get right and will print out blue'ish until heat pressed. Without the icc working they are really hard to get right.
To install the driver correctly you can download from the Epson website here -
I imagine as you've setup on WIFI Windows has just 'installed' the printer, which is fine in most cases for regular printing but with sublimation full drivers are required for setting the icm / icc and also setting the paper / quality settings.
Last thing would be to check the temp and time. I press mugs at 175c for 180secs. I start timer from closing heat press and removing when 180 secs expire.
Alex
You're right, I simply installed the windows driver when I added the printer. I'll install the Epson driver and give it a whirl.
Thanks.
Posted: 16 Aug 2019, 14:39
by InkExperts
Rusty;139558 wrote:You're right, I simply installed the windows driver when I added the printer. I'll install the Epson driver and give it a whirl.
Thanks.
Cool, I have edited my post to include the link.. forgot to put it in originally, its showing in my original post on page 1
Alex
Posted: 16 Aug 2019, 14:43
by Rusty
InkExperts;139559 wrote:Cool, I have edited my post to include the link.. forgot to put it in originally, its showing in my original post on page 1
Alex
What's your opinion on the matte versus glossy paper setting?
Thanks.
Posted: 16 Aug 2019, 14:49
by InkExperts
It shouldn't make much difference to be honest I have always set my printers (and my guides) to be Epson Matte and Best / High / Photo Quality.
When using our Subli-Fabric HR paper we do recommend slightly different settings - Plain Paper, High Quality, High Speed Print OFF.
I have never found much difference between glossy or matte paper choices. In reality they just tell the print to feed the paper slower and print a better quality really.
Alex
Posted: 16 Aug 2019, 14:58
by Rusty
InkExperts;139561 wrote:It shouldn't make much difference to be honest I have always set my printers (and my guides) to be Epson Matte and Best / High / Photo Quality.
Alex
Ok, thanks.
Just having a few issues with Photoshop since I've installed the Epson driver. The app crashes instantly when I press print now so just surfing google for solutions.
Posted: 16 Aug 2019, 15:03
by InkExperts
Had that with my CS6.. its an issue with CS6 and Windows 10. Only way I fix it is to open PS (no document open) > Edit > Preferecnes > Genral > Reset Preferences on quit
Close PS, reopen PS, open document > print > save
This saves the new print preferences / printer selection etc
Its a real pain, not quite worked out why but it appears to be a glitch between the OS and PS and Adobe wont admit to it so nothing online about it.
Alex
Posted: 16 Aug 2019, 15:10
by Rusty
InkExperts;139563 wrote:Had that with my CS6.. its an issue with CS6 and Windows 10. Only way I fix it is to open PS (no document open) > Edit > Preferecnes > Genral > Reset Preferences on quit
Alex
Oh I see. I did it the hard way before reading your message. Reinstalled PS and seems to have done the trick. Now printing with all the settings correct. Strangely enough the 'No colour adjustment' option was already selected.
I'll let you know how the press turns out.
Thanks.
Posted: 16 Aug 2019, 15:24
by InkExperts
Yep, often the driver will automatically select no colour adjustment when an icc is selected in PS. Not always the case but often is.
Alex
Posted: 16 Aug 2019, 15:32
by Rusty
InkExperts;139565 wrote:Yep, often the driver will automatically select no colour adjustment when an icc is selected in PS. Not always the case but often is.
Alex
Thanks for all your help (you too giraffe). It's not perfect but it's pretty darn close to the colour on screen.
Here's the before and after:
https://ibb.co/wC66ftL
Cheers guys.
Posted: 16 Aug 2019, 15:35
by InkExperts
Rusty;139566 wrote:Thanks for all your help (you too giraffe). It's not perfect but it's pretty darn close to the colour on screen.
Cheers guys.
Good to hear Rusty.. it should be about 90-95% in most cases with sublimation
glad I could help matey! And thanks for the custom and support!
Alex
