Horizontal lines on mug after sublimation.!!please Help!!
Jesh2002
Re: Horizontal lines on mug after sublimation.!!please Help!!
Post by Jesh2002 »
Justin;137933 wrote:Which inks? Have you set your software and printer settings up properly? Profile?
My money's on the printer.
thanks for your reply!! What setting I have to do on printer/software.?
please advice.!!
What inks are you using? Where did you buy them?
cyprian.costelloe
Post by cyprian.costelloe »
On an epson usually high quality, standard paper, turn off high speed and turn on mirror image
Sent from my K10 using Tapatalk
Wasting your time if you don't have a profile installed. You need to give us info above to help.
Jesh2002
Post by Jesh2002 »
Justin;137935 wrote:What inks are you using? Where did you buy them?
hi
i am using sublimation dye ink got it of eBay which is compatible with epson wf2630.!!
and sorry I don’t know how to set profile etc as I said I am very new to this!! I am so sorry 😐
Jesh2002
Post by Jesh2002 »
cyprian.costelloe;137936 wrote:On an epson usually high quality, standard paper, turn off high speed and turn on mirror image
thanks I will try this setting anything else you advice. Any setting in software’..? I use photopad editing software.!
OK, first thing you need to know is that the supplier of the ink can continue to supply the same ink. Next time you order if it's not available or has changed you will have to start again with a profile etc.
If they are a reputable seller I would expect them to help you with a profile. If they can't you will need to get a custom made profile to get the colours to work properly.
Personally I'd avoid any non branded inks on eBay unless they have a proven track record. Inks aren't expensive nowadays as you're no longer tied to Sawgrass for supply.
Speak to your supplier about the profile, you can't go any further without it. That probably won't be causing your lines issue though but won't help.
Have a good search on the forum as you'll find a wealth of information already on here about profiles, setting up etc.
Jesh2002
Post by Jesh2002 »
Justin;137941 wrote:OK, first thing you need to know is that the supplier of the ink can continue to supply the same ink. Next time you order if it's not available or has changed you will have to start again with a profile etc.
you think that’s causing horizontal line in image or nothing to do with profilev
cyprian.costelloe
Profiles are to make the printer print the colours correctly. So if the colours were off in your design that would be the issue.
cyprian.costelloe
Put up a picture of the paper print you did the mug with, the used one.
