Re: Images not printing correctly on thinner items
Posted: 15 Apr 2019, 20:32
If you press is printing fine then do not worry about the temperature reading. IR thermometer’s are wildly inaccurate anyway.paul 44;137819 wrote:well ive stripped a teflon sheet off one of the plates, did a heat check on the plate with the IR thermometer, reading is half what it should be 170f on thermo 356f on heat press but coasters are printing fine, i think thermo is goosed as 170f is only 76 Celsius, i couldn't touch the plate, too hot...new thermo i think!
