Best paper to use with Sublinova Dye Sub inks
pw66
Re: Best paper to use with Sublinova Dye Sub inks
Post by pw66 »
Also a fan of the S;race/Sublinova/Epson combination. Doesn't curl when printed which helps for large t-shirt prints. Find it best to allow the paper to dry for 10-20min when using the best quality Epson settings.
Very good blacks.
Post by GoonerGary »
I have the best setting photo quality, plus matte paper in the profile. You'll need to have an icc profile made for your ink. Times and temp are dependant on your set up and require trial and error.
Daninho
Post by Daninho »
GoonerGary;141754 wrote:I have the best setting photo quality, plus matte paper in the profile. You'll need to have an icc profile made for your ink. Times and temp are dependant on your set up and require trial and error.
I will get the ICC profile from ink Experts for the sublinova ink but its for their Versa paper which i ordered as well. I will test the S-Race as well.
