This has got to be one of the most confusing threads I've ever read!
To the OP: What printer are you using for your mugs? What printer are you using for your t-shirts? What inks are you currently using in these printers?
Until you answer these basic questions then I'm afraid you won't get any helpful answers.
Printing profiles
Re: Printing profiles
Mugs, orca coated. I use sublimation inks. Using ricoh pinter.
Tshirts same ink and printer as mugs.
webtrekker;136398 wrote:This has got to be one of the most confusing threads I've ever read!
Ok. Thanks.aidy999;136394 wrote:What's the best printer for mug sublimation using pigment inks. And the colours are fantastic using sublimation dye based ink.
If you are printing without a profile and getting excellent results then you're luckier than I am!
Yes, you can use sublimation inks on 3g transfers, I've done so myself, but only for tote bag designs which are rarely, if ever, washed. I've never tried this on t-shirts so don't know how they'd withstand washing.
Why do you print your designs from the context menu? Why not print directly from PS or Coreldraw?
The tshirts printed with 3g Jet opaque are totally washable no fade at all. I found the colours not great when printing from ps or cdraw.
webtrekker;136405 wrote:Ok. Thanks.
Yes I am using sublimation inks with 3g jet, should I not? And could I just use my epson dye based inks?
JMugs;136380 wrote:Are you using sublimation inks with the 3g jet opaque? Pauls remark is because sublimation inks are not normally used for this type of printing, although they can be.
Janners
