Genie III Mug press. Yes. That "black's not black" problem!
Re: Genie III Mug press. Yes. That "black's not black" problem!
On the Genie III I have occasionally used I do the following:
170 Idle
175 cooking
and because the blanket is well worn I am at 120 seconds.
170 Idle
175 cooking
After three tests, I finally landed on 180 deg. for 180 secs and everything looks fab!GoonerGary;134822 wrote:Bear in mind that different presses, ink, papers and mugs will give you different times. But try 170 degrees and between 120 - 180 seconds will get you started!
Many thanks for your help, GoonerGary, and thank you to everyone else who took the time to respond as well. I appreciate it.
What is a budget mug press suggestion these days?
Printer owners / BMS out of stock.
wanting to add a couple more ... or should i be thinking ovens? - how many clamps to get, - and where from?
thanks
thanks
Personally reading between the lines on your request LB I would get a halogen oven and about 8-12 clamps. Halogen ovens allow 4 mugs at a time are nice and small/economical and pretty cheap at £30.logobear;137303 wrote:What is a budget mug press suggestion these days?
thanks
The only oven I would recommend is the one I have which might be a bit too industrial and is more for bulk mug orders (I figured you are more ones and twos etc)
If you wanted to stay with a mug press then the Genie III is the only one I would recommend. Great unit, very quick, pretty cheap and has Listawood back up. I think It is also sold by a couple of other suppliers.
I've got a great Adkins mug press for sale in the Selling section. I could part with a second one if interested.logobear;137303 wrote:What is a budget mug press suggestion these days?
thanks
I would think its the other way around, because if you start the timer as soon as you clamp in your mug you will have the problem that your time/temperature setting can harder be reproduced because some mugs are room temperature, some heat up quicker etc... So i would avoid to name a complete press time, i think it is better to start the timer once the mug reached the desired temperature in you press. I try to find such a mug press and i want to avoid mug presses that dont offer that feature.GoonerGary;134816 wrote:That's correct. I try to avoid presses with idle temperatures, so these times are based on straightforward 'start immediately' presses.
I do also own a Genie press which has the idle and starting temperature set at identical settings.
is that 180 seconds after the mug reached 180 degree or 180 press time in complete?MikeJB;134829 wrote:After three tests, I finally landed on 180 deg. for 180 secs and everything looks fab!
What I do now is turn on the mug press, then wait for the temperature to get to 180 degrees. I then put in the mug*. The temperature immediately starts to drop of course - usually for me down to about 155/160 - then I wait for it to get back up to 180. As soon as it hits 180 I start a 30 second timer. Once the timer goes off, I remover the mug remove the paper and dip it into lukewarm water.
*I almost always warm up the bottom 1/2 inch of the base of the mug before pressing as this is the area of the mug that stays the coolest.
Daninho;141813 wrote:is that 180 seconds after the mug reached 180 degree or 180 press time in complete?
Ah that was clearer, so your time is actually 180C - 30 seconds in terms of the MPR-3 AKA Genie 3 mug press.MikeJB;141814 wrote:What I do now is turn on the mug press, then wait for the temperature to get to 180 degrees. I then put in the mug*. The temperature immediately starts to drop of course - usually for me down to about 155/160 - then I wait for it to get back up to 180. As soon as it hits 180 I start a 30 second timer. Once the timer goes off, I remover the mug remove the paper and dip it into lukewarm water.
Print Equipment in germany sells the exact same press under the name MPR-3, they are the makers of sublisplash inks and they recommending times for their products. In case of MPR-3 + sublisplash it is 175 Celsius for 70 secs. So they go much longer than your time. 30 secs is one of the shortest times i can remember with this press.
So i think for other inks 180 C is a good temperature and 60-120 secs, as a noob i would say this depends on how large the print is and the colors. IF i buy the Genie 3 i will surely test your 30 secs as well ! I guess i will waste 10-15 mugs with different timings
