Re: First mug success (ish)
Posted: 10 Dec 2010, 23:47
You never said which 'ink' you are using Frankie?
If you're using 'fleabay' special sublimation ink then this can have a mind of it's own (my opinion, I had problems at the start - check out one of my earlier posts .............. others find it great), plus the paper you are using which can affect the transfer from paper to gas to mug.
Then if all that's right you can then finalise the timing and temperature.
