Page 2 of 2
Re: Dye Sub Virgin!
Posted: 06 Apr 2018, 23:01
by wilde-one
bms;131260 wrote:You should also pop in and see Graham at The Transfer Press..
Thanks bms - What a great supplier - and local too. I will take a proper look at their website tomorrow but really good to have someone relatively close. bms, you aren't too far away either - just over the border! Am I correct in believing you are printerowners.co.uk?
Re: Dye Sub Virgin!
Posted: 07 Apr 2018, 09:13
by bms
wilde-one;131264 wrote:Thanks bms - What a great supplier - and local too. I will take a proper look at their website tomorrow but really good to have someone relatively close. bms, you aren't too far away either - just over the border! Am I correct in believing you are printerowners.co.uk?
Yes that is us. With Graham being so close to you then you can pick up and when you’re starting out being able to pop in for one of these and one of those is a great bonus as I expect you’ll have lots of testing to do. Have a look out for end of line items which may be cheap or giveaways so you can test without too much expense.
