Tips on mug printing
snjokaggl
Re: Tips on mug printing
Post by snjokaggl »
You can actually build a "Mac" these days with PC computer hardware. (Just install MacOs on it)
But you need to choose your parts carefully and only use the same as Mac does, now days they use the same stuff as everyone else.
You can save 40-50% off just to assemble it yourself. (won't look as pretty though)
Then you just sublimate an Apple and glue it on! (Just call it MyMac so you won't get sued)
bikertec
Post by bikertec »
Kaz;12424 wrote:Try upping the time to 180-200 seconds and see if that helps.
And it's a good idea to make the image smaller, that way you can use the same wasted mug a good few times
Does that mean I can use a mug more than once in the press, If so I have wasted so many mugs. :(
Ride it like you stole it shiny side up.
mrs maggot
Post by mrs maggot »
no, i think what they mean, is that by using a smaller image rather than a full wrap, you can put several images on a clean part of the mug each time
Dave S
Post by Dave S »
TailoreChocs;12477 wrote:Ok.... now I'm not sure if I said I was blonde.... but....
Nobody told me there was a wrong and a right way for the paper to print!!!!!!
Turned it over and hey presto!
Sorry for wasting everyones time!
Melissa
Been there and done that! and no I'm not Blonde Either, LOL
Dave Stones, Redcar.
Wish I knew Years Ago what I Know Now!
jennywren
Post by jennywren »
Some these are good helpful tips, could the not be put into tips and hints,
welsh phil
Post by welsh phil »
It sounds as if you are just putting the mug in the press then starting the timer.
Put the mug in the press and wait until the temperature goes back up before starting timer.
Has thanked: 11 times
Thread is nearly 5 years old Phil :-(
welsh phil
Still learning my way around lol:rolleyes:
Re-Employ
Post by Re-Employ »
We are having problems with printing images onto Mugs, the red is coming out either brown or orange, despite the fact that it comes out red on the paper.
Can anyone advise
