printed heat transfers from sinotransfer - samples
AdamB
Re: printed heat transfers from sinotransfer - samples
Post by AdamB »
Paul wrote:Ok. sorry people! I forgot all aout this topic :)
I still got some small samples so if any one wish to try one out hen drop me pm with your address and I stick one to the envelope and post it to you.
PM sent Paul - many thanks mate you're a star!
say 500 A4 sheets (each with a transfer) would that incur a HUGE import charge?
This would depend on a couple of things - (1) the value of the goods declared on the commercial invoice that would be supplied with the product and (2) the % duty that is attracted to that type of commodity.
The % duty varies depending on what it is - a commodity list and % duty is available from companies that deal with imports (or it might be found somewhere on Google!).
AdamB
Post by AdamB »
Hi Paul,
many thanks for the samples, which arrived very swiftly :-)
I never caught the info on application of them so it was a guess - I did 160 degrees for 15 secs and then tried to hot peel, so that wasn't working so I pressed again for a couple of seconds and then cold peeled .......... sorted.
I put one on each arm of a t-shirt and have put the t-shirt in a 40 degree wash and then straight in the dryer for a tumble.
Both transfers have stayed on and have no signs of peeling so I must give them 100% !
Many thanks mate
Adam
sorry. I should attached this info in the envelop :(
any way... 150C for 8sec. :D
AdamB
Post by AdamB »
Are you getting any done Paul as I was going to send him a PM regarding a quote - not sure if savings can be made doubling up on an order?
it can be ;) as they charge £50 setup cost for frames or something... then £1.20 per sheet if I remember... if you ask them for a quote I can get some done too ;)
just let me know what they say.
AdamB
Post by AdamB »
Paul wrote:it can be ;) as they charge £50 setup cost for frames or something... then £1.20 per sheet if I remember... if you ask them for a quote I can get some done too ;)
Just PM'd them mate - i'll let you know ;-)
sinotransfer
Post by sinotransfer »
hi everyone, thank you Paul and everyone for your positive feedbacks
heat transfer machine, heat transfer paper
www.sinotransfer.com
