Which Mug Press?
SussexShirts
Re: Which Mug Press?
Post by SussexShirts »
Hi,
I use the Ricoh3110 which is absolutely fine for good quality A4 sublimation. I'm using cheap ebay ink at the moment which gives surprisingly good results but I'm pretty sure it won't wash well! I'll probably switch to Sawgrass once I'm through the testing stage. The mugs I have done have faded (but only very, very slightly after 2 weeks solidly in the dishwasher!).
There are some good value starter packs and you get 10% off with Listawood.
The problem I've had initially with the mugs is the bottom of the image faded. This seems to be a common problem as the base takes longer to heat and so to sublimate. Some seem to have different methods of warming the base but as I say, I just out the idle temp lower and it has solved it for me. It may be the mug but as I get good results from my method now I'm going to stick with the mugs and what I'm doing.
Good luck with everything.
Sedgewick
Post by Sedgewick »
Really help info, thanks! I'm also looking to get a mug press and I was wonderful how to print to the base of the mug as I'd want the company logo there. You seem to be saying that with a Genie 111 you can print at the base of the mug. I've never pressed a mug and my assumption was that you could only press the sides of it. How would you print the base? Does the Genie have a smaller attachment for printing on the base?
SussexShirts;126993 wrote:Hi Cigilgan,
The Genie III has worked very well for me. A very sturdy bit of kit and simple to use. I am using Listawood mugs as well and the only issue I had initially was the bottom of the cups not printing well but I solved this but turning the idle temp right down to 130 and then letting the press come up to temp of 170 with the mug in it. Other than that I'm using all standard times and temps in the manual and getting great results.
I'm not exactly doing 200 mugs a day though! :)
Quinsfan
Post by Quinsfan »
You can't print the bottom of a mug. When they say base they mean the very bottom of the sides. Hope that makes sense
Sedgewick
Post by Sedgewick »
Ah...I see! I thought it sounded too good to be true! I guess you guys are all supplying mugs to companies, but I will be supplying to consumers, so I wanted to do some marketing by having the company name at the base/bottom of the mug. Anyway, thanks very much for letting me know.
Sedgewick
Post by Sedgewick »
I've looked that up and it says of ICC: "This method requires the graphics software application and OEM driver to be pre-configured before use." I wish I knew what "pre-configured" meant in that context. My graphics have been created already -in ai format. I wish I knew what configuration is needed to print on a 10 or 11 oz mug on a RICOH. I would like the same image on the front and back.
And is ai the right format? I know that high resolution is key but what is the optimum format for printing a medium detail black and white graphic onto 10 or 11 ounce mugs!
I promise that all I have been doing is scouring the internet for information but there are so many contradictions out there!! Any advice gratefully received!
Message Chongsta on the forum, and he can make sheets of round clear vinyl labels to brand the bases of your mugs - he supplies us and a few other members
Our kitchen cupboard is full of mugs, some dating years back. We have mugs we bought ourselves and mugs given as gifts and, in all honesty, I have never taken notice of anything printed on the bottom of a mug. Personally, I think it's just an unnecessary expense, but that's just my opinion.
Sedgewick
Post by Sedgewick »
You know what, Webtrekker, neither have I!!
I just feel like when I buy products from successful companies they've got their logo everywhere. Packaging gets thrown away, emails often go unopened - but a mug is such a presence I feel almost obligated to brand it.
I might start selling them and see how they do and maybe later consider the bases of the mugs.
Many thanks to Pisquee for suggesting Chongsta - I will definitely contact him if/when I go ahead with branding the bases.
Why not get some base printed blanks?
LW sell decent mugs and for an additional 10p per mug (plus a screen charge of about £20) they will print a 1 colour base. If you became a premium member it will work out pennies more than if you purchase them as a junior member because you get a 10% discount. See below as a rough example....
Below is based on 144-864 mug qty
List Price of AAA grade 10 ounce mug: 96p
Price of AAA grade 10 ounce mug as a Premium DSF Member: 85.4p
Screen charge £20 (or thereabouts)
Price per base print 10p
Based on 504 units
BLANK 96p
BLANK DSF DISCOUNTED 85.4p
BASE PRINTED BLANK WITH DSF DISCOUNT 99p
Obviously all plus VAT and delivery.
So you need to weigh up if adding a base print adds 13.6p to the value of the mug. If it does then get some printed. If not then don't bother.
Sedgewick
Post by Sedgewick »
Incredibly helpful, social giraffe. I am probably going to put that idea on hold until I see if my mugs sell. It's a great idea though although I wasn't looking to get Listawood mugs.
I'm sure they're good but after doing all my research my understanding was that BMS mugs are the absolute best? I want mugs that can withstand dishwashing to a point that it's guaranteed, and I understand that they the best as they have an RN coating rather than Orca or Rhino, etc.
It would be so helpful to see what discounts are currently available for members here. I have no idea if there is a discount on BMS mugs. I am looking to also buy a cheap RICOH A4 SG311ODN printer with the sawdust ink, a cheap but professional quality mug press (£120 is my limit but so tempted by the DF1+ Genius Mug Press as it's the only affordable press that I can find that is branded and from a reputable supplier, as opposed to finding it on Ebay which can be hit or miss.
I also need to buy 72 or 100 sublimation mugs, cut paper (I am rubbish at cutting in a straight line). I suppose it's impossible to do all that for £300?
I have already bought white smashproof boxes, but was surprised only one supplier seems to do smashproof COLOURED mug boxes. Shame they're expensive as I did want to get them!
Anyway, thanks for your help, just wish I knew if membership here would make sense, given what I want to buy.
