Page 2 of 2
Re: Galaxy Air 4in1 GS-204 Pneumatic Mug Press
Posted: 16 Feb 2018, 14:25
by pw66
Very dangerous, glad no one was hurt.
Careful with anything that uses a compressor. HSE has recently been around our estate targeting all compressor users. Making them get everything pressure tested - cylinder, piston, pipes and airlines as well as the tools and machinery all had to be tested. One of my neighbours had to pay about £1500 for testing and a further £600 fees to HSE ( they charge £128+vat per hour 'fee for intervention'). It is only a matter of time before they realise that print shops and screenprinters often use compressors, and we become their next 'cash cow'.
Posted: 16 Feb 2018, 14:35
by webtrekker
pw66;129850 wrote:Very dangerous, glad no one was hurt.
Good advice, and also consider whether your insurance will pay out if you haven't had your gear certified.
Posted: 16 Feb 2018, 16:44
by anniecov
Fortunately (or not) we don't need to use this compressor any more. :wink:
Posted: 18 Feb 2018, 01:55
by arthur.daley
anyone using a small compressor - you might want to consider just buying another cheap compressor from Machine Mart or the like every 12 months to avoid the need for inspections and giving the old one away. Of course if you need something a bit special - ultra quiet, oil less etc which generally doesn't come cheap you are going to have to bite the bullet and pay out for inspections.
If I remember correctly this has all been driven following a couple of incidents with barrista machines - they store steam under pressure which is really bad news if anything lets go - which is apparently what happened.
Arthur
Posted: 18 Feb 2018, 09:21
by webtrekker
Personally, I'd steer well away from using a compressor for the sole purpose of closing a mug press when other, far less dangerous, methods exist. If I was snadblasting or airbrushing then yes, fair enough, I'd have to have a compressor, but for pressing mugs I don't see the need.
I'm pleased no one was injured Annie. Apart from the emotional aspect, it could have seriously damaged your business.
Posted: 18 Feb 2018, 13:11
by arthur.daley
not much snadblasting going on in the average print shop but plenty of people use pneumatic flatbed presses
Posted: 18 Feb 2018, 16:50
by webtrekker
arthur.daley;129883 wrote:not much snadblasting going on in the average print shop but plenty of people use pneumatic flatbed presses
I mentioned sandblasting (sand carving) because sandblasted mugs and other items look great and I was considering doing this myself, but I don't think I'll bother now! I'm too young (66) to die!
Posted: 20 Feb 2018, 08:29
by Forgetful8
The biggest problem with compressors is lack of maintenance.
I wonder how many users actually drain the tank at the end of the day? It's amazing how much water ends up in them!! Obviously water & steel tends to result in corrosion...and the insides of the tanks generally aren't painted.
The other issue with water is that it can accelerate corrosion between 2 different metal types...like at the manifold...
