Subli t - platen marks remain after printing.
accdave
Re: Subli t - platen marks remain after printing.
Post by accdave »
Shipz wrote:Is that the same Graeme that does the plastisol transfers from Artbrands etc.
Yes it is. Something I've been going to order for the past 2 years, but can never make my mind up which ones to get :D
Kaz
Post by Kaz »
Hiya, have you tried the suggestions already mentioned on this thread?
Has thanked: 13 times
Been thanked: 12 times
kris_hm
Post by kris_hm »
Justin - I think Shipz means marks from heat plate edges, not paper edges.
I had the same problem and I'm also using xpress t-shirts. Please try to reduce temperature but extend the time. That should reduce heat press marks a little bit and then straight after pressing quick ironing with loads of steam. It works for me ;)
My apols! That'll teach me to read threads quickly ;-)
mgibbs
Post by mgibbs »
When I print tees I always use the press afterward to iron out the lines (avoiding the printed area obviously).
Doesn't get rid of them completely but it does reduce them.
Mark
Printingtshirt
Post by Printingtshirt »
I think you should try this http://thetshirtman.co.uk/ .
twinsgran
Post by twinsgran »
I realise this is an old post but I just wondered if anyone over time has perfected the art of printing t shirts without leaving the platen mark? I did a polo shirt this morning as a trial and I was careful to avoid pressing over the buttons and I ripped the edges of the paper with the image on it. I put a sheet of paper inside the shirt and then covered the lot with a large sheet of paper. [yes I know, that's a lot of paper]. Anyway the image came out fine and there were no paper edge marks, but the platen marks were definitely there. I pressed at 185 for 60 secs. I used a steam iron on it immediately after but you can still see it. Any suggestions please?
