Mug press problems
Re: Mug press problems
But what inks are you using?
sterbyc
Post by sterbyc »
inks were included with your printer, sublimation ink, Name no.
If you don't know what inks you have how can you be sure they're even sublimation inks? How will you maintain consistency and buy identical inkset?
Let's try a different route :-)
When you opened the printer what cartridges did you put in the printer?
Were they from the red boxes with SAWGRASS printed on them (as shown in one of your images) or were they other cartridges you had from somewhere else?
Reg
Post by Reg »
He said he's using refill cartridges that came with the printer it could be he hasn't taken the travel plugs out of the cartridges and getting a weak mix.
sterbyc
Post by sterbyc »
I bought a set for sublimation printer + sublimation ink (refill cartridge) You are think that I have to buy a new color?
On a Ricoh they are closed cup systems I think. I have one and the refillable carts for mine don't even have travel plugs. I could be wrong on that though.
Send us pictures of the following:
The label on the bottle of the ink you purchased
The printer with the carts installed
A print from your printer on sublimation printer (ideally a block of CYAN MAGENTA YELLOW and BLACK)
A nozzle check from the printer
sterbyc
Post by sterbyc »
printers use Ricoh aficio SG 3110DN printer is a new
https://ibb.co/nqZAGF
https://ibb.co/nOzcwF
https://ibb.co/eZqT3v
https://ibb.co/cksaiv
Hard to be sure but looks like the carts aren't venting. Have you unplugged the smaller of the two rubber plugs in each cart when installing them? This needs to be done to stop airlocking.
Can you send a picture of the nozzle check and also print a sheet of four squares. 1 @ 100% Cyan, 1 @ 100% Magenta etc ec
