3D Printer alternative for phone cases
3D Sublimation
Re: 3D Printer alternative for phone cases
Would anyone know if these transparent cases work with film in the ST-3042 Machine?
The cases will print using paper, you just need to play around with the temp and time to get it spot on. You can not use film in the 3042 as you can not get the accuracy needed for placement, unless you have made some sort of jig or come up with a good work around.
