Which are quickest ovens for bulk orders, that are least expensive?
cyprian.costelloe
Re: Which are quickest ovens for bulk orders, that are least expensive?
Post by cyprian.costelloe »
Personally I just use mug presses, three on the go give me on average one mug every minute.
Sent from my HTC One_M8 using Tapatalk
brightday83
Post by brightday83 »
cyprian.costelloe;120189 wrote:Personally I just use mug presses, three on the go give me on average one mug every minute.
Yes, but mug presses aren't great for designs that go all the way up to the handles, and edges :frown:
cleverprintinguk
Post by cleverprintinguk »
So, did we find a good oven for £1500/£2000 which can produce good amounts of mugs?
Customprintwales
Post by Customprintwales »
I use halogen ovens from B&M Bargains for £30 each but they are pretty much bog standard models that you can find anywhere for that sort of price.
I love them and get much better print than when I used a mug press. Top to bottom is much easier to do as there is no pre-heating to do and using wraps you can get the design much closer to the handle without worrying about fading.
It can take a while to press one mug - I use 18 minutes for a mug - but timing get much better when you do more mugs. I can get 6 in at a time and the timing on that is 28 minutes. for 4 at a time the time is 23 minutes.
At £30 a time I have bought 3 so when I do bulk orders I can do up to 36 mugs an hour. Just make sure you have enough wraps to operate smoothly.
Customprintwales
I use the brown silicon wraps because I find the fastenings much more reliable.
The green ones have a single tension latch and if they get slightly dented that have a habit of springing of during the baking. The brown wraps have hook and eye fastenings and have a much more secure fixing.
Customprintwales;120213 wrote:I use the brown silicon wraps because I find the fastenings much more reliable.
Can I ask: What type of oven do you use?
Customprintwales
I used a standard halogen oven you can find in most shops.
I used to use the domestic oven until the other half started to tap her foot and give me a mean look because the Sunday roast was sitting on the counter not in the oven :)
Customprintwales;120215 wrote:I used a standard halogen oven you can find in most shops.
Hi, thanks for that. I deleted my post when I realised you had already mentioned B&M ovens in your previous post.
We have a local B&M and I was looking at their Tower ovens the other day. For the price, I may give it a whirl. At the very worst, I can still use the oven for pre-heating mugs for my mug presses.
Earl Smith
Post by Earl Smith »
I have a daft question on the subject of ovens. Why does nobody suggest using a kitchen oven? Surely you would get many more in one of those.
We did - bought a full sized kitchen oven from Argos, fan assisted, top and bottom heat elements, could get 24 mugs in at a time.
Problem was to get consistent heat in the whole oven, the fan was needed, but the fan would blow around any gassed ink that had escaped off the transfers, and so any exposed areas of the mugs got a browny tinge on them.
Other problem was our mugs aren't a standard size, and the silicone wraps available were too big, so we had problems with not having enough pressure around the whole mug.
We ended up with tape around the whole transfer so no ink gas could escape, so went through so much heat tape which wasn't cheap, the increased labour time/cost to wrap the mugs in this way was also therefore expensive.
We wasted a few hundred mugs trying to perfect this, and had to give up in the end, and move back to presses unfortunately.
We cleaned the oven down, and it's now in our kitchen doing a fantastic job of cooking food, replacing the gas oven we had which was terrible at cooking and was condemed by the gas board for being too leaky!
