Page 2 of 2
Re: Printer won't print
Posted: 21 Oct 2010, 20:20
by marymare
Hi Martin,
No it's not Sawgrass ink, I sort of thought that as I would waste alot in getting going and perfecting the process that I would waste the cheaper ink first then move onto the proper stuff when I was a competent mug printer. I feel it could be the cartridges.
Posted: 21 Oct 2010, 20:36
by marymare
Hi Martin,
No I don't have Sawgrass ink as I figured that as I was sure to waste a load of mugs and ink whilst getting to grips with mug printing, I would waste the cheaper stuff. I think it could be a problem with the cartridges (gut feeling). Once I have perfected my printing I will switch to the real stuff.
Posted: 21 Oct 2010, 20:52
by marymare
Don't know why but all of a sudden it is printing. I asked it to print a load of solid blocks and away it went......Don't feel so blonde anymore!
Thanks for all the help. No doubt I will be back.
Posted: 21 Oct 2010, 21:00
by accdave
marymare wrote:Hi Martin,
You can't perfect your printing if your using cheap inks
Posted: 21 Oct 2010, 21:10
by marymare
Too true.but I can perfect the getting it onto paper and mug ... straight.. and getting the templates the right size etc. I will get the real stuff soon as I know it is heaps better, just got to watch the pennies to start with so I can experiment away.
Can't wait to get going now.
How do you put a picture on your profile?
Posted: 21 Oct 2010, 21:29
marymare wrote:How do you put a picture on your profile?
User Control Panel in top left........Profile Tab.......Edit Avatar
Posted: 21 Oct 2010, 21:31
by Paul
do you want to bet???
its all about profile you using...
Posted: 21 Oct 2010, 21:35
by marymare
Thanks for the tips on the profile pic, and what inks and profiles do you suggest if it's not Sawgrass?
Posted: 21 Oct 2010, 21:59
by accdave
marymare wrote:and what inks and profiles do you suggest if it's not Sawgrass?
Simple answer... none
Posted: 22 Oct 2010, 07:43
by bms
First port of call will be your supplier of the inks. If that doesn't work then you may have to get a custom profile made if the colours are off.
