Sublicotton on Epson 325
Mugshots
Re: Sublicotton on Epson 325
Post by Mugshots »
Correction. Mine says Sublitocotton on the back of the paper?
decca591
Post by decca591 »
Hi Mugshots
I use my old Epson and it is working fine, almost fool proof, and I am following the guidelines as recommended - print, Coat, Press 45 secs,
Prepress garment for 5 secs, get it absolutely right, and place the printout in one movement, you cant move it, at all - the ink remains wet and will smudge if you move it - cover with Teflon sheet, and press , allow it to cool and just peel off, I have had excellent results from day one with this - would like it cheaper but hey ho !
I wanted to be able to print on cotton, and this pretty much does the job - I am using pretty much cheapo inks - again I wanted to try it out, and will deffo move up to see if I can get crisper images, but to be honest, these are good to go !
will post some images later, let me know how you go on - you could try posting BMS, also on this thread.
Just a quick thought, you are printing, coating, pressing - you cannot allow the ink to dry, not tried it but I'm wondering if that's your problem as BMS warned me about it - you must press asap !!
Decca
Mugshots
Post by Mugshots »
I did press straight away. I take it your using photoshop? Any settings I should try?
decca591
Post by decca591 »
Hi
No- Corel Draw (x7) no special settings, just import / create my images or text and print out to my Epson 235, powder coat and press - sometimes it doesn't need to overly complicated !!!
Try BMS, sounds like you need the experts.
maybe your dye sub inks ??
Decca
Mugshots
Post by Mugshots »
Ive got it working great. Unsure what happened 1st time. Just a slight problem of some small specks on the image that wasnt on the paper.
Mugshots
Post by Mugshots »
Just used that logo as a test
decca591
Post by decca591 »
Glad you got it sorted !
I bought a canal cruiser recently and printed the logo on to a T, really simple and brilliant results !!
Good luck !
Decca
Mugshots
Post by Mugshots »
Canal cruiser?
decca591
Post by decca591 »
Cruiser, as opposed to a Narrow boat !!
the missus is trying to coax me into retirement, bought this a few weeks ago, gutted the inside and just putting it back together ;-)
She see's it as me relaxing, I see it as an ideal advertisement for my vehicle lettering and T'shirts !!!
Decca
