Printing issue and mirroring
MrMuggins
Re: Printing issue and mirroring
Post by MrMuggins »
Well it's printed in mirror but the preview in Powerdriver isn't. This is a bit of a pain as it's not me who's doing the printing all the while and I'm trying to keep this as simple as possible for wifey. It's not that she's daft or anything it's just how I originally showed her to do it.
Galaxy Pro GS 202 Mug Press and Ricoh SG3110DN Printer
KathG
Post by KathG »
Which program are using ? .........As in CorelDraw when using the PowerDriver it never shows the mirroring. Also just checked in Photoshop and that is the same...only shows the mirroring if you use the mirroring in Photoshop but not when using in PowerDriver
Cheers
Kath
MrMuggins
Post by MrMuggins »
KathG;112315 wrote:Which program are using ? .........As in CorelDraw when using the PowerDriver it never shows the mirroring. Also just checked in Photoshop and that is the same...only shows the mirroring if you use the mirroring in Photoshop but not when using in PowerDriver
I use Photoshop then print the files from Dropbox as I do all the designs on a different computer. Its worked fine on my wifes laptop with this setup, the problem only happens on the new laptop.
KathG
Post by KathG »
So you use DropBox to print from?
Cheers
Kath
MrMuggins
Post by MrMuggins »
KathG;112318 wrote:So you use DropBox to print from?
Yes, never had the problem before using the same setup on anther laptoo
mrs maggot
Post by mrs maggot »
powerdriver never previews in mirror - but as long as mirror is ticked, it will print it reversed
MrMuggins
Post by MrMuggins »
mrs maggot;112326 wrote:powerdriver never previews in mirror - but as long as mirror is ticked, it will print it reversed
You're not wrong. Sawgrass replies with the same. I could have swore that it mirrored the preview. Hey ho
Users browsing this forum: Google [Bot] and 5 guests
