wasted about 6 new mugs to get time/temp set so blacks come out jet black, and full top to bottom coverage...
sorted..
that was a far cry from when we first started out.....2 cases of 36 mugs later lol :rolleyes:
Quinsfan;111310 wrote:I am always looking for a good review for mug presses and this Galaxy seems a good buy. I have a Jarin press at the moment and it took 8 mugs to print 4 decent ones. Have always done 300 secs at 180 no probs and now faded middle then bottom and finally top. Faded in different areas on each mug!!! In the end i had the bottom part of the mug in the press for 1 1/2 mins to warm it up to take the print, and then I have to make sure the mug is exactly in the right place of the press or it will not print the top properly.
I may go back to my halogen oven that is under the desk as I never had an undercook/pressure issue just overcooked sometimes when i forgot to start the timer.
hiya..surekellieW;111319 wrote:Can I ask what you found to be the best heat setting and time to work? I've received mine today and without wasting anymore mugs I thought easier to ask you.
thanks
Jerry;112430 wrote:Great review, bigj2552.
Alas I've had this mug press GS-201 for a week and it's terrible. Here's the bad points:
I'm not sure if I've received a faulty machine from SignzWorld or if I'm asking too much for a press at £115. This is my first press so looking to either get a working one or upgrade to the PRO version?
- Cold spots 2cm at each end.
- Uneven pressure (I'm using 10oz double layer mugs). Close it to breaking point and I can still slide paper along the sides.
- Heat platen lead is dangerously short and very tight when you apply pressure onto a mug.
