Re: Which Mug press
Posted: 28 Jan 2016, 22:59
Nearly all my designs are top to bottom and 210mm round. Some are flat colours like you're using there. I use an adkins for this. Works perfectly. Have blown up several mother boards and blankets though, but they have always replaced them free.
I think the main thing is the blanket is a lot softer than most and conforms to the mug better. Also I use BMS mugs, or listawood when BMS are out of stock. Both good mugs but listawood stain terribly with tea drinkers.
Hope that helps.
Hope that helps.
