Page 2 of 2
Re: Black printing "faint" - coming out brown when pressed
Posted: 02 Jun 2015, 18:09
by Pea
Justin;101717 wrote:Also....check the black is 'black' in your software and not made up from other colours.
Im using CorelDraw - where can I double check that setting ?
The black i have selected shows as : R:0 G:0 B:0 when hovering over it
Posted: 02 Jun 2015, 18:12
by Pea
Paul;101716 wrote:is clear film taken off before you pressed?
Yeh film removed before being pressed.
Posted: 02 Jun 2015, 18:16
by Pea
Ok so I have been having a look at the printer settings and noticed i've been using Epson Ultra Gloss ! ..
Changed it to Epson Matte and the image being printed appears darker ..
Then unticked fast print and tested again but that seems just the same ..
See picture for more reference - though i still think it has a tint of brown even before pressing it .. Is that normal ?
Top right is Gloss, Top left is matte .. bottom middle is Matte and Fast Print unticked
vB_ID:3513
vB_ID:3513
Thanks.
Posted: 02 Jun 2015, 18:40
by Paul
is not even point to try to fix it if you print on epson settings. You will need proper icc to get it right. but again... if you dont know brand of your ink so there is no point making custom icc really...
Posted: 02 Jun 2015, 18:42
by Pea
I had a dig around in the box I received with the printer etc and there is an invoice from "Natureinks" so I could only guess that that is the brand of inks I was supplied with ?
Thanks.
Posted: 02 Jun 2015, 19:41
by Pea
Seems that changing the paper type to matte instead of glossy fixed the problem :)
Now coming out a lot better black.
(Ignore the white bits it was only a test)
vB_ID:3514
vB_ID:3514
Posted: 08 Jun 2015, 19:14
by Ravisteam
Hi try paper type matt hevy weight paper and unclick hi speed printing..should work..
