mini 3d machine - anyone had good results
3D Sublimation
Mattie
Re: mini 3d machine - anyone had good results
Post by Mattie »
kendog;101012 wrote:no bother man, my consience got the better of me so i edited listing before
if you want the unit only message me on ebay...
I believe items should be listed honestly, then you will have no come back. This is why I don't like buying second hand from Ebay etc.
I've no use for all the 3D cases that come with it as all old models and already have loads in stock so at £160 I might as well buy new
Matthew
kendog;101007 wrote: are you happy with unit paul?
i love my machine. it took a little bit of trial and error but no i know how to set up my machine to get descent results.
magda
Post by magda »
Paul;101014 wrote:i love my machine. it took a little bit of trial and error but no i know how to set up my machine to get descent results.
I might get one of the mini machines. I have the bigger one st3042 by the same manufacturer but it just broke this evening with a big spark and pang, pretty scary! Happened when I opened the lid. So if it can't be fixed I'm considering replacing it with the mini. Even if it can be fixed I'm probably going to be scared of being electrocuted now each time I open the lid. I wonder if the rubber heat gloves saved me...
Paul, do you get good results with phone cases with the mini machine?
I was getting good results with the big one using paper. Didn't try mugs yet only cases. The main reason I went for the bigger machine was the possibility of pressing more than one case at a time. But I had resorted to doing them just one at a time as the vacuum pressure in my machine was a lot better in the centre, the vacuum never quite wrapped as well on items that were not placed right over the suction hole. So if I need to replace my machine I might as well get the mini. Plus I can't afford to buy a new big one.
