Silhouette Cameo
malfunction
Re: Silhouette Cameo
malfunction;99087 wrote:Did you manage to get your Rowland working ok?[/QUOTE
hi malfunction and good morning to you ,i have not had a chance to try it yet been very busy in work (normal job) british army been away for a few days in liverpool on a shooting competition ,i got a couple of days spare now so will be having a go today and tomorrow ,thank you for asking mate
tried again with this after buying the db25 parallel adapter but i still cant get it to recognise my computer ,i think the problem might be my computer is 64 bit and the cx24 runs of 32 bit ,so decided to buy the cameo instead ,thanks for your help guys
How are you getting on with the Cameo ????tiamaria;99153 wrote:tried again with this after buying the db25 parallel adapter but i still cant get it to recognise my computer ,i think the problem might be my computer is 64 bit and the cx24 runs of 32 bit ,so decided to buy the cameo instead ,thanks for your help guys
hi buster i think it is a really clever little machine it has done everything i have asked it to do ,i can not fault this machine in any way at all ,although the weeding is a pain when your eyesight is not 100% ,it is easy to weed some fonts but more finer intricate fonts can be a little tricky but it would be with any cutter ,so untill they make a vinyl cutter that will self weed i will be happy with the little cameo
For older vinyl cutters without USB ports or without drivers on the latest windows, run the cutter on a Serial cable.
Get a USB to Serial adapter and a Nul-Modem cable with the correct ends.
All sign programs I've come across will drive the cutters over a serial port. The Roland Cutters run at 9600 baud,8 data, No Parity and 1 stop bit Hardware handshake.
This method will drive all the Rolands back to the PNC1000 from the early 90's
Serial port adapters will work on all version of windows including Windows 8.1 64 bit.
Its probably best to buy from someone like Kevin at Wissen UK (google for them) who understands cutters.
Alan
Alan
went ahead and purchased a Silhouette Cameo after all., Im still finding my way though I've printed few t-shirts for stag & hen parties so far......Also using the vinyls for few personalised sign ideas as well which look great and fingers crossed will take off........
