Re: better mug press or 3d mini vacuum?
Posted: 25 Nov 2014, 22:11
Although loud it does help to have the vacuum turned on.but you're not using the vacuum
The reason I say is because if you are doing a full bleed mug with colour running off the top and bottom you will inevitably have paper and subsequently ink overlapping the mug. As you know the ink turns into a gas. To prevent this ink from "landing" somewhere it shouldn't (i.e. inside the mug) I turn the vacuum on to suck it out of the oven.
I hope I have explained that properly
