better mug press or 3d mini vacuum?
Re: better mug press or 3d mini vacuum?
but you're not using the vacuum
Although loud it does help to have the vacuum turned on.
The reason I say is because if you are doing a full bleed mug with colour running off the top and bottom you will inevitably have paper and subsequently ink overlapping the mug. As you know the ink turns into a gas. To prevent this ink from "landing" somewhere it shouldn't (i.e. inside the mug) I turn the vacuum on to suck it out of the oven.
I hope I have explained that properly :-)
gavtheoldskater
Post by gavtheoldskater »
really interesting, thanks. think an adkins or similar quality press maybe the way to go then. not fussed about phone cases or anything like that.
