Epson, Roland or Mutoh?
Re: Epson, Roland or Mutoh?
Were looking to buy a 24" sublimation printer, but have been told that even though epson might be cheaper it will be more expensive in inks. Im not sure Roland do a 24" version? Can you get a continuous ink system for Epson? Im used to Epson and especially as were on macs would be better. Can anyone advise?
would you not be better buying a 40" plus printer to escape the sawgrass monopoly?
Are you planning to print sublimation with this printer? Are you already printing sublimation with a smaller printer? The size of printer is the main governing factor when it comes to ink cost. Sawgrass licences ink to the supplier for anything that is classed as small format (less than 42" ot thereabouts). Ink will basically cost 4 times as much as the large format option where Sawgrass don't have a say.
Yes. I already have an Epson I use for canvas and art prints, so Im looking for a separate printer to print sublimation.
Is that even for real Epson inks too? Are you saying an epson 24" isnt economical or just any printer that size?
It's nothing to do with ink economy through usage really. You can use exactly the same ink for a printer but if it is used in a printer classed as small format you will have to pay 4 times the cost so Sawgrass take their substantial cut. They have patents in place that state you can only buy ink licensed by them for printers smaller than 42". On large format printers they have no say so you can buy the same ink for a 1/4 of the cost. Having said that, I would say that for a newbie it is easier going down the Sawgrass route as they make it far easier with it being a supported printer option. Only with more experience would I suggest non-supported wide format. Learning the basics is hard enough so keep it less complicated.
For large format printers, some of the printer manufacturers have their own sublimation inks, and have support options, including Epson themselves, along with Roland and Mimaki (as far as I can remember) Inktec also offer support options.
The odd thing with Sawgrass is that their consumer side think that 24" is small format, whereas Sawgrass Industrial will happily sell their wide format Sublim ink to 24" printer users.
In terms of the actual patent wording it makes no mention of printer size, and this separation of the market at 42", was the result of one of the many legal battles, and an out of court negotiation between Sawgrass and BASF (if I remember correctly) Interestingly, the patent which has always been disputed in the past actually expired in September last year.
