Redesigned website
Re: Redesigned website
Just about finished with my newly designed website,
still got products to add but slowly working on them, got few banners to add/change and few other small things
click the link in my profile and let me know what you think.
Matthew
Looks nice but alas not working very well for me in Chrome
I upload an image nice and smoothly and added to cart and nothing happened so a quick butchers hook around and I see maybe I have to save it...and a pop up appears and I click new account (or something like that) and get the dreaded wheel in motion for at least a minute....and way longer than I would wait to place an order
Looks great but needs more explanation for ordering process...and any bugs need fixing.
If you drop a note here when fixed for Chrome I'll check again for you.
Strange works fine for me in chrome.
Popup is just a tick box asking customer to confirm they have checked the for designs mistakes. I can remove that give me 5 mins
Matthew
I have removed the popup
to order all you have to do is upload image add text etc then select case colour from dropdown next to add to cart button then click add to cart
Matthew
ah something has changed
I can now see - well I cant see it without highlighting the text that I need to tick the box that the design is good - but as it is now not many people would be able to see that
The only popup that will ask you to create an account is the one if you click the "save design" button so that you can come back to it later.
I've remove the check design popup that was just a trial thing, I wasn't a 100% myself on it
Matthew
Guys, where you get the empty case graphics from? Liam looking for couple to print on poster for the shop wall.
Source them from all over Paul some are custom made for me
Matthew
Looks GREAT to me. You've done a good job with Fancy Product Designer!
I'm also using chrome. Display is fine and designer functions fine.
Only problem is share buttons and "add to cart" don't do anything, and When I click save I just get a blank white box.
