cushion covers 100% polyester
Re: cushion covers 100% polyester
Hi there,
I wonder where you buys getting your cushion covers from?
looking for 12x12,14x14
thank you!
James990
Post by James990 »
I get mine from BMS but I also believe Coralgraph do some as well.
James
We cut and sew them in-house after printing the fabric, so not limited by size, material, or quality of ready made blanks, also printing the fabric before making into a finished item gives a much better end product.
DebbieS
Post by DebbieS »
I get fabric from The Transfer Press and have also noticed the finished look is a lot better if you print before sewing up the item.
rossdv8
Post by rossdv8 »
Mine are mostly done for marine use (pleasure boat cabins). We buy reasonable quality white polyester bed sheets cheap in Queen or King size, print, cut and sew inside out. Last lot worked out costing us around 30 cents each per cushion for material.
Material is placed over a square of MDF, and a 'frame' of MDF is then placed over that to grip the material in place wrinkle free and nice and square.
