Help with inks
Cheshire cat
Re: Help with inks
Post by Cheshire cat »
Hi guys please could you advise me on what inks i should use for printing mugs.
Is there a big difference between brands.
Pete
Andrew
Re: Help with inks
Post by Andrew »
If you have the epson then artainium tends to be the safe bet. More support and choice about as it's the most popular.
Re: Help with inks
Agree with Andrew - for Epson the most popular choice is the Artainium brand and if you go for a Ricoh printer then it is only the SubliJetR brand of ink.
Do you have a printer at the moment that you're going to use for sublimation ink - what is it?
Cheshire cat
Re: Help with inks
Hi guys thx for your replies.
In answer to your question Martin I have an Epson B40W.
Cheers
Pete
Andrew
Re: Help with inks
Post by Andrew »
Artainium it is then.
Re: Help with inks
The Artainium inks for the B40W come in what is called an EasyFlow system. This contains 100ml of Artainium sublimation ink for each colour so you get 400ml in total in a continuous ink system. Supplied also is a CD containing the ICC colour correction profile as well as various help files for setting the system up.
We usually have them in stock from the link below:
http://www.printerowners.co.uk/sublimat ... inters.htm
