sheilds wanted
Re: sheilds wanted
After all that I said about the about sheild, ( never again, here am I asking does anybody know where I can buy them from, I've tried sbub supplies I need 50 to a 100. where can I try,
Re: sheilds wanted
I checked the suppliers list out, none have, or similar, I know it was old stock the sub supplies had. I was wondering if the almuminium sheilds would do but I need the wooden part as they have over 50 odd pubs and want me to do one or two for each pub. so i'm looking for a regular supplie or bulk buy. Is there anywhere else I could try.
Re: sheilds wanted
That looks ideal, there must be a glue tha would hold sheild and wood, Spot on mate 10 out 10. Thank you very much Paul, it will be nice to fulfil this order. My other half has just said the sub dye dosen't work well on almuminium, is he talking out of his backside.... I have a couple of sheets hidden somewhere I might give a go.
Re: sheilds wanted
No problem Jennywren! Iam glad I can help.... If there is no wood shape you like I am sure if you phone them up they will cut it for you:) I dont know what kind of aluminium you have but when I done my aluminium business cards they come up lovely!
Re: sheilds wanted
Try Xpres for your shields, they are under PLAQUES, 25cm shields,code XP4039, cost £7.25each.
Hope that helps a bit,
Ray
Ray
